DirtRider.Net DirtRider.Net Dirt Bike - Motocross - Supercross Forum
The Forums at DirtRider.Net
Go Back  Dirt Rider . Net Forums > Bike Info By Brand / Type > 2-Stroke Discussion > Canadian Daves JustKDX
User Name
Password
Where is all my coolant going?
Reply
Thread Tools Search this Thread
Similar Topics
Old 10-30-2001, 05:24 PM
Braahp Braahp is offline
Subscriber
Where is all my coolant going? 2001 200. Things are usually ok but if I'm really riding hard I seem to be losing quite a bit of coolant. Appears to not be leaking anywhere. Heck I rode a hard 15 mile loop last weekend at Loretta Lynns and it was all gone from my resevoir. Cylinder didn't seem that hot to the touch. Other loops used up coolant also but not as much. Like maybe halfway between full and low lines. This was my first ride since installing Devol radiator gaurds. Could they make it run hotter? I seen other posts where they say the Devols made no diffence. Any ideas appreciated.
Old Related Info / Links
  #2
Old 10-30-2001, 05:28 PM
ride_red_15 ride_red_15 is offline
Uhhh...
Send a message via AIM to ride_red_15
are you positive theres no leaks? what about a leak INSIDE the engine? that has happened before...also, are you using the correct coolant mix ratio?
  #3
Old 10-30-2001, 05:53 PM
Canadian Dave's Avatar
Canadian Dave Canadian Dave is offline
Super Power AssClown
Not to worry the coolant is escaping out the overflow tank's vent tube when the bike is being jarred around trail riding. Most people, including my self, don't run any coolant in the overflow tank. The level in the rads is maintained no problem and if the bike does overheat and dump its fluid it goes to the tank anyway. To confirm that's the case with your bike check the coolant level in the rad before you ride and again the next day. Be sure its cool before opening the cap. I'm sure you'll find the level is staying consistant.
David
  #4
Old 07-23-2002, 08:18 PM
23jayhawk's Avatar
23jayhawk 23jayhawk is offline
Just a bump to bring this to the top.
David, are you saying that even with a perfectly tight system, one would expect to blow some coolant out the reservoir? I have lost maybe an inch or so from the reservoir in 15 hours of run-time since new. The temps have been low to mid 90's during most rides. I have never seen fluid coming out the tube, but at the rate it is going down, it would be difficult to see.
------------------------------------------------------------------ « t a g » -----
Ken W.
  #5
Old 07-23-2002, 08:27 PM
Fred T's Avatar
Fred T Fred T is offline
Lifetime Sponsor
Send a message via AIM to Fred T
My overflow tank is always empty but when I check my Rad it's full every time. Some folks just toss the overflow bottle and run a hose down the frame instead.
* If any of the comments posted by me are offensive to you, or hurt your feelings please place a complaint to arbitration committee leader Wolverine423.
  #6
Old 07-24-2002, 10:06 AM
clutchcover's Avatar
clutchcover clutchcover is offline
Subscriber
Send a message via MSN to clutchcover
Mine never stays past the low line. But as Canadian Dave said, the radiators are always full.
  #7
Old 07-24-2002, 10:13 AM
DENNY DENNY is offline
Registered
I would remove the tank. I had the same problems 10 years ago so I removed my reservoir and 3 KDX bikes later with zero problems.
  #8
Old 07-24-2002, 10:24 AM
cudmak cudmak is offline
Registered
My 01 220 does the exact same thing. I keep the overflow tank and just top it off to full line about every 3 to 5 rides. Takes like 2 secs with a 8mm socket to remove tank shrouds. It's just part of my normal routine along with WD-40 on chain, test chain slack, make sure air in tires, fire it up, grip it and rip it.
Seeya
  #9
Old 07-24-2002, 11:33 AM
23jayhawk's Avatar
Well, that settles it - no worries, mate.
More proof this forum is the best thing since disco.
  #10
Old 07-24-2002, 04:34 PM
speedyts49's Avatar
speedyts49 speedyts49 is offline
Subscriber
Send a message via Yahoo to speedyts49
I did a 50 mile loop last weekend in 90' weather at 4k to 8k ft and lost all of my overflow and about an inch out of my radiator. Half of the ride was single track low gear stuff. I thought I had lost my rear brake due to all the fluid on the rear wheel and brake rotor. Did I mention I dropped the bike 4 times? I have since changed from a 150 main to a 158 and put in a b9 es instead of the b8 es I had in. Any thoughts? Oil is clean, no water in engine.
tom
'93kdx200 stock
Reply
Search this Thread:
Advanced Search
General Reviews For Sale Ride Thumpers MX / SX Chapters Suspension KDX What Bike?
Copyright 1999-2005 DirtRider.Net
Dirt Bikes , Motorcycles, Motocross , Supercross , Off-Road , GNCC, ISDE, MX1, MX2, MX de Nations, Dirt Bikes, Trail Bikes, MX Photos, CMRC, Racing, Desert Racing, Arenacross, MX Video
Motorcycle Parts, MX Gear, New Motorcycles, Used Motorcycles, Honda, Yamaha, Kawasaki, Suzuki, KTM
