DirtRider.Net DirtRider.Net Dirt Bike - Motocross - Supercross Forum
The Forums at DirtRider.Net
Go Back  Dirt Rider . Net Forums > Help / Advice, How-To's & Performance > Mods, Performance & Repair
User Name
Password
Rear axle stuck
Reply
Thread Tools Search this Thread
Old 03-21-2005, 05:52 PM
justwannaride justwannaride is offline
Registered
Rear axle stuck
I have a 99 yz 250, that I purchased used last year. Should the rear axle slide out, once the nut is removed , the chain tensionor loosened and chain removed? I tried hammering the axle thur but it started pulling the bearings out of the wheel with the axle. How do you remove the stuck axle? Thanks for any help.
Old Related Info / Links
  #2
Old 03-22-2005, 12:15 PM
nickyd nickyd is offline
Registered
the axle should slide out.....ahh, the joys of not greasing the bolt - it probably has seized to the collar in the hub (between the bearings)....>I've had luck pounding them out (ruined a punch, the bolt and my finger too)....once we had to wedge the swingarm out and fit a cutting wheel in to cut the axle so we could get the wheel off. good luck.
  #3
Old 03-22-2005, 04:01 PM
Magellan's Avatar
Magellan Magellan is offline
Lifetime Sponsor
Same thing happened to my front axle. Siezed up (was also bent) due to not servicing it after a muddy ride (went swimming), and then forgetting about it for a while.
Here's what I did:
1) penetrating oil whereever I could get it
2) Hot rag around the hub
3) deadblow and a drift.
The bearings came with it. I replaced the axle and bearings.
If it is siezed to the spacer, I would replace it as well. You may be albe to apply some heat to the spacer, but be careful. You're working in tight quarters. I heat gun would be preferable to a torch.
good luck.
mag
------------------------------------------------------------------ « t a g » -----
2004 Gas Gas EC300
2001 Bultaco Sherco 2.9.
1975 Honda CB400F - stock and on the road
1975 Honda CB400F - Cafe Racer Bound
1986 Honda TLR 200 Reflex - Commuter
1986 Honda TLR 200 Reflex (2) - future projects
2004 XR70
2005 Yamaha PW50
1987 Kawasaki KDX80
Reply
Search this Thread:
Advanced Search
General Reviews For Sale Ride Thumpers MX / SX Chapters Suspension KDX What Bike?
Copyright 1999-2005 DirtRider.Net
Dirt Bikes , Motorcycles, Motocross , Supercross , Off-Road , GNCC, ISDE, MX1, MX2, MX de Nations, Dirt Bikes, Trail Bikes, MX Photos, CMRC, Racing, Desert Racing, Arenacross, MX Video
Motorcycle Parts, MX Gear, New Motorcycles, Used Motorcycles, Honda, Yamaha, Kawasaki, Suzuki, KTM
