DirtRider.Net DirtRider.Net Dirt Bike - Motocross - Supercross Forum
The Forums at DirtRider.Net
Go Back  Dirt Rider . Net Forums > Bike Info By Brand / Type > 2-Stroke Discussion
User Name
Password
Will Yzf450 04 bud clamps fit yz125 06
2-Stroke Discussion
Reply
Thread Tools Search this Thread
Old 01-05-2007, 12:05 PM
bobturnip bobturnip is offline
Registered
Will Yzf450 04 bud clamps fit yz125 06?
Old Related Info / Links
  #2
Old 01-06-2007, 12:09 AM
Matt90GT's Avatar
Matt90GT Matt90GT is offline
Registered
Send a message via Yahoo to Matt90GT
no. The 06-07 uses clamps that moves the forks 2mm wider than the 04-05 units.
  #3
Old 01-06-2007, 02:17 AM
Dekester Dekester is offline
Registered
The above information may be incorrect. I tried to clarify in what aspect 2mm he is referring to here and in my post about whether the steering issue in 05 was changed in the frame or the triple clamp of the 06.
Yamaha moved to 48 mm forks in 2004. 05-07 are also 48 mm but different forks, AOSS in 05 and SSS in 06. The 04 was bumped to 48mm and was the same style as previous generation 46 mm forks.
There are 2 questions you need answering. One is if the diameter of the mounting area of 04 and 06 forks is the same. The second question you need to know is if they changed the fork angle in 06 via the triple clamp or the frame steering neck. If they changed the angle in the frame, the clamps should have the same rake and be interchangeable as long as outer tube mounting diameter is the same. See my post below for any updates and I will try to remember to let you know when I find out.
One guy in my post said the 04 and 05 clamps are interchangable which leads me to believe that the 04/06 should be interchangeable as well as long as the fork rake was changed in the frame and not the triple clamp. It might physically work but your fork angle would be changed and would have likely negative impact on handling.
  #4
Old 01-07-2007, 01:38 PM
Registered
Thank you
Reply
Search this Thread:
Advanced Search
General Reviews For Sale Ride Thumpers MX / SX Chapters Suspension KDX What Bike?
Copyright 1999-2005 DirtRider.Net
Dirt Bikes , Motorcycles, Motocross , Supercross , Off-Road , GNCC, ISDE, MX1, MX2, MX de Nations, Dirt Bikes, Trail Bikes, MX Photos, CMRC, Racing, Desert Racing, Arenacross, MX Video
Motorcycle Parts, MX Gear, New Motorcycles, Used Motorcycles, Honda, Yamaha, Kawasaki, Suzuki, KTM
