DirtRider.Net DirtRider.Net Dirt Bike - Motocross - Supercross Forum
The Forums at DirtRider.Net
Go Back  Dirt Rider . Net Forums > Bike Info By Brand / Type > 2-Stroke Discussion
User Name
Password
Honda cr125 top end???
2-Stroke Discussion
Reply
Thread Tools Search this Thread
Old 12-15-2004, 08:06 AM
criss criss is offline
Registered
Recently rebuilt my friends 2000 cr125 top end, (new cylinder,piston,rings,ect).After starting up he complained no power nd low compression.Stripped it back down nd discovered that the cylinder the shop sent me was a "A" nd the piston "B".Everything looks ok,nd the shop when they checked with honda said this combo is ok.Anybody have any similar problems?Also the ring end gap is .020",is this ok?
Old Related Info / Links
  #2
Old 12-15-2004, 08:41 AM
steve125's Avatar
steve125 steve125 is offline
Lifetime Sponsor
The difference between the A and B pistons are only .0005 very small difference. Yep the ring gap is a bit on the large size at .020 but thats a std Honda ring for ya
So for what U have said so far, the bike should run at least as good as stock. Or was there another problem to begin with, before the top end rebuild??
  #3
Old 12-15-2004, 08:59 AM
TWRT TWRT is offline
Registered
Was the power valve cleaned and re-installed properly? Had a friend loose all low end from an incorrectly re-installed power valve. He corrected it and regained all low end.
  #4
Old 12-15-2004, 09:51 AM
Registered
Cr 125 rebuild problem?
Just replaced the cylinder,piston,nd rings on my friends 2000 cr125.After starting it up it lacked power,nd had a knocking sound.We stripped it down again nd found the new cylinder was a A size nd the piston B.I checked with the shop that sold me the parts nd they said they checked with honda who said this combo was ok.Also the ring gap was .020".Is this ok????
  #5
Old 12-15-2004, 11:56 AM
steve125's Avatar
Lifetime Sponsor
The .020 ring gap along with the piston mix up are NOT your problem. PV stuck?? or not opening?? old fuel?? slipping clutch?? reeds??......keep searching.
  #6
Old 12-16-2004, 12:13 PM
Registered
Thks for the help guys,now i know the cylinder,piston/rings are ok i'll start looking at the powervalve nd bottom end.
  #7
Old 02-21-2005, 05:39 AM
Risveden Risveden is offline
Registered
As long as it is honda original parts you use: A is bigger than B. Some aftermarket piston use reverse marking(B bigger than A)
Reply
Search this Thread:
Advanced Search
General Reviews For Sale Ride Thumpers MX / SX Chapters Suspension KDX What Bike?
Copyright 1999-2005 DirtRider.Net
Dirt Bikes , Motorcycles, Motocross , Supercross , Off-Road , GNCC, ISDE, MX1, MX2, MX de Nations, Dirt Bikes, Trail Bikes, MX Photos, CMRC, Racing, Desert Racing, Arenacross, MX Video
Motorcycle Parts, MX Gear, New Motorcycles, Used Motorcycles, Honda, Yamaha, Kawasaki, Suzuki, KTM
