DirtRider.Net DirtRider.Net Dirt Bike - Motocross - Supercross Forum
The Forums at DirtRider.Net
Go Back  Dirt Rider . Net Forums > Help / Advice, How-To's & Performance > Suspension Q&A with Jeremy Wilkey
User Name
Password
Tire pressure?
Reply
Thread Tools Search this Thread
Old 02-18-2007, 01:35 PM
banzai132 banzai132 is offline
Registered
Tire pressure?
My manual (clymer) says to use 19psi of pressure in my tires F/R. However, my bike slides alot. Could I lower my pressure to 12psi without any adverse effects (pinch flatting, bead popping off the rim) and still be ok?
Thanks, Bob
Old Related Info / Links
  #2
Old 02-18-2007, 03:31 PM
JST122 JST122 is offline
Registered
19 psi is actually pretty high pressure for your tires and is not really ideal for motocross. You may run that high if you are trail riding because the extra pressure helps protect against pinching the tube and punctures when coming in contact with rocks and logs. But for motocross you will typically run your tire pressure between 10-15psi. You want to run a higher pressure on hard pack and a softer pressure in loam or sandy conditions. In the hard pack conditions out in California I run 12 psi in the front and 13 psi in the rear.
Check out this article it has some good basic info: http://www.transworldmotocross.com/...1563748,00.html
  #3
Old 02-18-2007, 07:03 PM
Registered
Thanks JST. I ride on mostly sand here in florida, but there is the occasional rocky section.
  #4
Old 02-18-2007, 09:26 PM
adam728 adam728 is offline
Registered
19 psi is high. My Maxxis tires have fairly stiff sidewalls, I run 12 psi front and 10 psi rear in the rocks. On less rocky trails I'll go 10/8 f/r.
  #5
Old 02-19-2007, 09:47 AM
Oldman125's Avatar
Oldman125 Oldman125 is offline
Registered
Quote:
Are you using "soft" or "sand" specific tires? Soft sand takes an aggressive tire to plow through the surface and not fill up. The result of using a tire with small or closely spaced knobs (hard terrain spec) will be sliding around a lot.
Reply
Search this Thread:
Advanced Search
General Reviews For Sale Ride Thumpers MX / SX Chapters Suspension KDX What Bike?
Copyright 1999-2005 DirtRider.Net
Dirt Bikes , Motorcycles, Motocross , Supercross , Off-Road , GNCC, ISDE, MX1, MX2, MX de Nations, Dirt Bikes, Trail Bikes, MX Photos, CMRC, Racing, Desert Racing, Arenacross, MX Video
Motorcycle Parts, MX Gear, New Motorcycles, Used Motorcycles, Honda, Yamaha, Kawasaki, Suzuki, KTM
