DirtRider.Net DirtRider.Net Dirt Bike - Motocross - Supercross Forum
The Forums at DirtRider.Net
Go Back  Dirt Rider . Net Forums > Bike Info By Brand / Type > 4-Stroke Discussion
User Name
Password
06 crf250r clutch issues
4-Stroke Discussion
Reply
Thread Tools Search this Thread
Old 12-29-2007, 12:02 PM
mike E72 mike E72 is offline
Registered
hi, i have a 06 crf250r. I recently put a set of pro circuit heavy duty clutch springs in and am now noticing where the bolts that hold the springs against the pressure plate are making the inner hub mushroom where the bolt screws into it. with the bolt mushrooming the hub i am finding metal flakes in my oil.
Has any one else had this problem?
How can i fix it?
Old Related Info / Links
  #2
Old 12-29-2007, 12:18 PM
crf250rjcd5151's Avatar
crf250rjcd5151 crf250rjcd5151 is offline
Registered
Send a message via Yahoo to crf250rjcd5151
sounds like you might have torqued the spring bolts a little too tight, did you use a torque wrench and tighten to specs?? clutch springs are picky on the torque settings, I bought a used YZ125 a few years ago and the guy put new clutch plates in right before I bought it, he over torqued the bolts to the springs and I had the same thing happen. It fried the new clutch plates after just a couple of rides and had shavings when I changed the oil pretty bad.
  #3
Old 12-29-2007, 06:08 PM
Registered
i torqued them down to 9 ft lbs as it says in the manuel
  #4
Old 12-29-2007, 06:10 PM
Registered
the wear isnt happening on the outside of the hub its where those bolts screw into the hub. was this the same as yours
thank you
Reply
Search this Thread:
Advanced Search
General Reviews For Sale Ride Thumpers MX / SX Chapters Suspension KDX What Bike?
Copyright 1999-2005 DirtRider.Net
Dirt Bikes , Motorcycles, Motocross , Supercross , Off-Road , GNCC, ISDE, MX1, MX2, MX de Nations, Dirt Bikes, Trail Bikes, MX Photos, CMRC, Racing, Desert Racing, Arenacross, MX Video
Motorcycle Parts, MX Gear, New Motorcycles, Used Motorcycles, Honda, Yamaha, Kawasaki, Suzuki, KTM
