DirtRider.Net DirtRider.Net Dirt Bike - Motocross - Supercross Forum
The Forums at DirtRider.Net
Go Back  Dirt Rider . Net Forums > Bike Info By Brand / Type > 4-Stroke Discussion
User Name
Password
wiring acclerator pump to actuator on carb
4-Stroke Discussion
Reply
Thread Tools Search this Thread
Old 04-15-2008, 01:58 PM
JustinC628 JustinC628 is offline
Registered
I few people recommended me wiring the plastic acclerator pump arm to the metal actuator arm on my 05 CRF250R to help with throttle responce. The said it make a tremendous difference but I'm a little hesitant to do it. Have any of you guys done this mod? If so, all you have to do is wire the two things together? Are there any drawbacks to doing this?
Old Related Info / Links
  #2
Old 04-16-2008, 01:29 AM
XR250rdr XR250rdr is offline
Registered
Send a message via AIM to XR250rdr
Use an o-ring instead.
Like this:
  #3
Old 04-16-2008, 05:21 AM
_JOE_'s Avatar
_JOE_ _JOE_ is offline
Subscriber
You will need to remove the pump diaphragm down by the bowl. There is a rivet that nedds to be shaved down to allow more movement of the actuator rod. It will bottom out if you dont. If you can afford it, I would recommend the jd jetting kit. It comes with an o-ring to use rather than wire, and some main jets as well as a couple needles. You should switch to a larger leak jet if you shave the diaphragm though. Good luck!
  #4
Old 04-16-2008, 06:16 AM
BSWIFT's Avatar
BSWIFT BSWIFT is offline
Club Moderator
Send a message via AIM to BSWIFT Send a message via Yahoo to BSWIFT
Took me a minute to see the O-ring.
------------------------------------------------------------------ « t a g » -----
Member of an angry mob, TAXPAYERS!
2B Judged by 12, NOT carried by 6!
05 YZ 250T
05 Midnight Roadie
05 Scorpa SY250
  #5
Old 04-16-2008, 06:17 AM
whenfoxforks-ruled's Avatar
whenfoxforks-ruled whenfoxforks-ruled is offline
I never had issues with the rod bottoming out. You can buy a modded diaphragm and not risk making the rubber stiff grinding the nipple off. There is a aftermarket ap adjuster that supposedly takes care of having to wire it up. If you use the o ring, get a bunch, they wear out!
WHEN IN DOUBT, GAS IT! : 83CR480R, 97CR250R, 00CR250R 05CRF450
  #6
Old 04-16-2008, 02:58 PM
Registered
Thanks for the replys eveyone. I ordered a JD jet kit today, but the kit description didn't mention it came with the o-ring. So basically, just slip that o-ring around there and that's it? You don't have to adjust that spring or anything?
  #7
Old 04-16-2008, 08:54 PM
_JOE_'s Avatar
Subscriber
You should check the timing of the squirt while you are playin around with it(thats what the spring/screw is for). It should just miss the bottom of the slide when you open the throttle.
  #8
Old 10-28-2010, 11:30 PM
dmdee99's Avatar
dmdee99 dmdee99 is offline
Registered
Am I missing something because I don't see where the o-ring is??
Can someone enlighten me??????
When in doubt pin it out.
  #9
Old 10-29-2010, 04:43 AM
_JOE_'s Avatar
Subscriber
The o-ring is around the plastic actuator arm just below the cable wheel.
  #10
Old 10-29-2010, 05:33 AM
Patman's Avatar
Patman Patman is offline
Pantless Wonder
The O ring isn't being used in the normal O ring manner but more like a rubberband.
"I ride, therefore I crash." - Patman ~~~~ "Do or do not, there is no try!" - Yoda
Reply
Search this Thread:
Advanced Search
General Reviews For Sale Ride Thumpers MX / SX Chapters Suspension KDX What Bike?
Copyright 1999-2005 DirtRider.Net
Dirt Bikes , Motorcycles, Motocross , Supercross , Off-Road , GNCC, ISDE, MX1, MX2, MX de Nations, Dirt Bikes, Trail Bikes, MX Photos, CMRC, Racing, Desert Racing, Arenacross, MX Video
Motorcycle Parts, MX Gear, New Motorcycles, Used Motorcycles, Honda, Yamaha, Kawasaki, Suzuki, KTM
