DirtRider.Net DirtRider.Net Dirt Bike - Motocross - Supercross Forum
The Forums at DirtRider.Net
Go Back  Dirt Rider . Net Forums > Bike Info By Brand / Type > Moto Related Product Questions
User Name
Password
Best engine degreaser?
Reply
Thread Tools Search this Thread
Old 12-07-2008, 02:37 PM
yamikawi21 yamikawi21 is offline
Registered
Whats the best product to use to get a greasy-grimey dirtbike engine sparkling again?
Old Related Info / Links
  #2
Old 12-07-2008, 06:41 PM
longtime coming longtime coming is offline
Registered
elbow-degreaser and a brush. I'd try strong soap and water and some brushes. Engine degreaser can take off paint.
  #3
Old 12-10-2008, 05:02 PM
Uchytil's Avatar
Uchytil Uchytil is offline
Lifetime Sponsor
Simple Green will do an ok job and keep it safe for you. As a mechanic, and over the years, I've used diesel, Safety Kleen, and orderless mineral spirits. Never use gasoline. The solvents I mentioned are relatively safe and will cut crud well enough. You can follow up with a warm soapy solution if using solvents. Just remember not to pour the solvents out, rather, collect them in a leak proof container and take them to a recycle center (like the ones that take used oil). Like gasoline, I would also NOT use carb cleaner or brake cleaner partly due to cost and the are really made for specific tasks. Hope this helps.
  #4
Old 12-10-2008, 05:24 PM
cthowards's Avatar
cthowards cthowards is offline
Subscriber
I use Simple Green. I spray it on and let is soak in for a few mintues and then just rinse it off. On ocassion, I will take an SOS pad and lightly rub over the surface (and any other aluminum parts like the kickstarter, etc.) while the Simple Green is soaking in. That gets it really clean without scratching it up. I find that if I clean my bike weekly, then it is much easier to clean and it seems to look newer, almost like there is a cumulative effect of using Simple Green on a regular basis.
Good luck.
  #5
Old 12-10-2008, 05:35 PM
_JOE_'s Avatar
_JOE_ _JOE_ is offline
Subscriber
Quote:
Good luck.
I agree 100%. Simple Green, if used on a regular basis, is an excellent cleaner. I use a pressure washer as well, but use extreme caution around seals/electronics. If you keep up with it cleaning the bike will not take long at all and the results will be much better.
As far as breaking down built up gunk, carb cleaner and a stiff brush is hard to beat. You can get small wire brushes of different materials at most tool stores. Use one with small diameter bristles to prevent scratching. And as mentioned, avoid contact with paint and plastic.
------------------------------------------------------------------ « t a g » -----
I think my Throttle of Life is stuck WFO!!!
  #6
Old 12-23-2008, 12:17 AM
Registered
Couldnt bring myself to buy the more liquidy type stuff like simple geen or purple power.
Went with Gunk Foamy Engine Degreaser. Worked pretty good (not Excellent) but did no damage to the paint or surrounding rubber parts after 20 minutes. Did get rid of lots of nasty crap though.
thanks for the opinions.
-CUBE-
  #7
Old 01-28-2009, 10:37 AM
dirtbikerider123 dirtbikerider123 is offline
Registered
engine brite, stuff is amazing!
[Mod Edit - If you want add pictures to your posts you need to resize them to a maximum of 800 x 800. ]
  #8
Old 03-03-2009, 02:45 PM
GarbatyA4 GarbatyA4 is offline
Registered
I would use a GOOD Carb Cleaner (anything at Pep boys or CAnadian tire Sucks) and buy a couple 1 dollar brushes from the buck store. I use this to get all the chain lube gum up and on the swing arm.
Simple Green or Castrol Super Clean
  #9
Old 03-03-2009, 03:14 PM
allthingsdirt's Avatar
allthingsdirt allthingsdirt is offline
Registered
Mean Green's been working good for me for many years.
  #10
Old 05-30-2009, 01:31 AM
upnorthbacon upnorthbacon is offline
Registered
Simple green and an old toothbrush will do wonders for small areas. Spray on the simple green, let it set for a min, then dip the toothbrush in a container with simple green in it. The grease will rub off really easy, you just have to keep rinsing and re-applying the simple green to the toothbrush. Works great! Cheap electric toothbrushes work even better!
Reply
Search this Thread:
Advanced Search
General Reviews For Sale Ride Thumpers MX / SX Chapters Suspension KDX What Bike?
Copyright 1999-2005 DirtRider.Net
Dirt Bikes , Motorcycles, Motocross , Supercross , Off-Road , GNCC, ISDE, MX1, MX2, MX de Nations, Dirt Bikes, Trail Bikes, MX Photos, CMRC, Racing, Desert Racing, Arenacross, MX Video
Motorcycle Parts, MX Gear, New Motorcycles, Used Motorcycles, Honda, Yamaha, Kawasaki, Suzuki, KTM
