| The Forums at DirtRider.Net |
wiseco piston installation!
Canadian Daves JustKDX
03-24-2009, 05:01 PM
Registered
Hi, i'm doing my first top end on a 01' kdx220. I was wondering what the easiest way is to install those circlips for the wrist pin properly without bending them, I tried practicing with the old ones but it seems to be a pain and I ended up scratching the old piston? Also do you normally use a piston ring expander to install the rings.My concern is damaging these parts by bending them. Any advice would be appreciated. Thanks
03-24-2009, 05:39 PM
Registered
the rings will snap before they bend put the second ring on first by starting the end into the groove butted up against the little pin sticking out of the groove ...look closly there is a pin ther to stops the ring from moving... then with you other hand hold the ring out away from the piston as you use the other hand to put a finger on the ring where you started it ..then spiral ring into the groove untill you reach the end do the same with the top ring
as for the circlips
start with the ends of the clips pointed AWAY from the notch on the bottom of the piston pin hole then put the clip in at an angle starting with th open end first, then push the closed end into the hole making shure the clip "snaps" into the groove
hope this helps ..also maybe practice with the old piston and rings first
03-24-2009, 10:16 PM
Registered
practice practice practice! i used to not be able to get cir-clips in very well now i can get them in and out in no time.
------------------------------------------------------------------ « t a g » -----
My Garage: 1990 KDX 200, 1976 KZ900 LTD, 1995 CBR 600, 2005 450R, 1980 YZ50, 1981 XS650, 2005 Grizzly 660, 2002 Kodiak 400, 2007 RMZ-450
03-25-2009, 05:24 AM
Registered
Use a plastic cable tie to hold the rings in, it will slip down and can be cut away when you lower the barrel
04-08-2009, 12:01 PM
Registered
Make sure they are in right or this could happen:
04-08-2009, 04:27 PM
Registered
urgh thats bad!!
04-08-2009, 04:29 PM
Registered
here's the piston... even worse.
04-08-2009, 05:06 PM
Subscriber
Groovy!
I think my Throttle of Life is stuck WFO!!!
04-10-2009, 07:07 AM
Registered
The best set up I've ever seen was with an Arias HP piston that I put in an old XR-200.
The piston came with two teflon plugs that you installed on each side of the wrist pin to
keep it centered. A very slick and simple job, never had to worry about a c-clip.
I wonder why a company like Wiseco never adopted that theory ?
06-05-2009, 08:35 PM
BioHazard
Quote:
Because piston buttons are way too heavy.
It's not a coincidence that every major high performance piston manufacturer uses either Spiral Locks, or the Spring clips that Wiseco uses.
"another beautiful theory beaten to death by a gang of ruthless facts..."
- Tom Hanna (Master Metalshaper/Nitrogeezer)
[ DRN SupportTeam Info ]
| Thread Tools |
Search this Thread |
General
Reviews
For Sale
Ride
Thumpers
MX / SX
Chapters
Suspension
KDX
What Bike?
