DirtRider.Net DirtRider.Net Dirt Bike - Motocross - Supercross Forum
The Forums at DirtRider.Net
Go Back  Dirt Rider . Net Forums > Help / Advice, How-To's & Performance > Suspension Q&A with Jeremy Wilkey
User Name
Password
04 Honda CRF 450R Fork Oil
Reply
Thread Tools Search this Thread
Old 03-28-2009, 07:56 PM
blair_crf450r blair_crf450r is offline
Registered
Exclamation 04 Honda CRF 450R Fork Oil
How do I put oil in the forks of an 04 Honda crf450r?
Old Related Info / Links
  #2
Old 03-29-2009, 08:52 AM
sharky243's Avatar
sharky243 sharky243 is offline
Registered
Send a message via MSN to sharky243
Your bike has dual chamber showa forks. Remove the forks from the bike. Record the clicker positions and back off the clickers completely. Remove the top fork cap. Drain the oil from the outer chamber into a drain pan. Turn the top cap back in acouple threads to protect the threads. Flip the fork upside down, remove the bottom rebound adjuster. Push down on the lower fork tube, and insert a pushrod holding tool or an apropriot sized open end wrench under the locknut. Remove the adjuster from the pushrod, push down on the fork tube again and remove the holding tool. Turn the fork over again, remove the top cap, and pull out the inner chamber. Remove the compression chamber valve assembly. Drain the oil from the inner chamber. Pump the pushrod afew times to get all the oil out. This is the time to change your seals and bushings if needed. TO RE-FILL : Pour aprox. 6.6 oz of fork oil of desired weight into the inner chamber. Pump the pushrod afew times to expel the air. In your owners manual, there are level specs. Measure from the step at the bottom of the inner chamber inside to the top of the fork oil. Adjust oil level to desired measurement. Re-install the compression valve assy. Re-install the inner chamber in the fork tube assy. Fill the outer chamber with aprox. 12.5 oz of the fork oil you chose. Re-install the top cap into the upper fork tube. Re-set your clickers and install the forks back on the bike. It sounds complicated but it's really quite simple if you take your time and pay attention to what you're doing.
------------------------------------------------------------------ « t a g » -----
Life is way too short, live your dreams and have fun doing it !!!
  #3
Old 03-29-2009, 11:16 PM
Matt90GT's Avatar
Matt90GT Matt90GT is offline
Registered
Send a message via Yahoo to Matt90GT
http://www.motosport.com/dirtbike/tv.php
Pretty much the same steps except doing the seals.
Reply
Search this Thread:
Advanced Search
General Reviews For Sale Ride Thumpers MX / SX Chapters Suspension KDX What Bike?
Copyright 1999-2005 DirtRider.Net
Dirt Bikes , Motorcycles, Motocross , Supercross , Off-Road , GNCC, ISDE, MX1, MX2, MX de Nations, Dirt Bikes, Trail Bikes, MX Photos, CMRC, Racing, Desert Racing, Arenacross, MX Video
Motorcycle Parts, MX Gear, New Motorcycles, Used Motorcycles, Honda, Yamaha, Kawasaki, Suzuki, KTM
