| The Forums at DirtRider.Net |
2006 yz250 rear end slides to right
Suspension Q&A with Jeremy Wilkey
05-25-2009, 08:54 PM
Registered
I have a 2006 yamaha yz250 that I bought new. About 6 months ago I started to notice the backend seemed to want to push to the right in loose soil when excellerating or braking and the bike tends to stand up when making right turns and slide when turning left. I had the suspension revalved by a local servicers who specializes in woods type riding shortly after purchasing and everything seemed fine. Since I noticed the problem I have changed oil and seals in forks and changed oil in shock. I also have regreased linkage bearings and still notice the problem. Any suggestions what I can look at next. I have asked around and no one seems to know what to think.
05-25-2009, 09:02 PM
Subscriber
Rear wheel alignment or loose bearings.
------------------------------------------------------------------ « t a g » -----
I think my Throttle of Life is stuck WFO!!!
05-25-2009, 09:08 PM
Registered
How do you check the rear end alignment? Do you think this could be caused to worn stock rear wheel adjusters?
05-26-2009, 05:56 AM
Subscriber
Worn adjusters? Probly not but I guess anything is possible. Make sure the marks on the axle blocks and swingarm are set the same on both sides. Put the bike up on a stand and shake the rear end to check for worn bearings.
05-26-2009, 04:11 PM
Registered
Sorry, I guess I meant worn axle blocks. It is actually dented on the right one where the bolt meets it. They are properly set and bearings seem tight. I may just replace the bearings and axle blocks and see if that helps.
thanks
05-26-2009, 04:44 PM
Subscriber
How about the swingarm bearings?
05-26-2009, 08:00 PM
Registered
I regreased them when I did the linkage. They seemed fine but I will take off tire and subframe this week and see if there might be some play.
05-26-2009, 08:53 PM
Subscriber
Just get the rear end off the ground and try to push/pull the wheel side to side.
| Thread Tools |
Search this Thread |
General
Reviews
For Sale
Ride
Thumpers
MX / SX
Chapters
Suspension
KDX
What Bike?
