DirtRider.Net DirtRider.Net Dirt Bike - Motocross - Supercross Forum
The Forums at DirtRider.Net
Go Back  Dirt Rider . Net Forums > Bike Info By Brand / Type > 2-Stroke Discussion > Canadian Daves JustKDX
User Name
Password
Aircooled hybrid update 2
Reply
Thread Tools Search this Thread
Old 06-27-2009, 01:05 AM
arjay's Avatar
arjay arjay is offline
Subscriber
6 monthly progress report... here are how things are going. I've got all the bits together, kind of. The tank is work in progress - 2mm alloy cut out, shaped and tack welded together. It needs a bit of fettling before getting the seams fully welded. The rear guard is loosely in place, as are the side panels. The frame needs a couple more lugs welded to take the tank and CDI and skidplate, then powder coating in Kawasaki green. Then comes the scary part - finding out how this thing handles...
Old Related Info / Links
  #2
Old 06-27-2009, 01:11 AM
arjay's Avatar
Subscriber
A few more pics
  #3
Old 06-27-2009, 01:14 AM
arjay's Avatar
Subscriber
and...
  #4
Old 06-27-2009, 06:59 AM
julien_d julien_d is offline
Registered
Man, that's looking really sharp! What frame are you using there?
  #5
Old 06-27-2009, 01:49 PM
SVandal's Avatar
SVandal SVandal is offline
Registered
Nice tank on there. Did the stock one not fit with the pipe? Would it work with the pipe cut and moved? Just hoping you don't dent the tank, its too nice to ever lay the bike over.
------------------------------------------------------------------ « t a g » -----
2003 CRX 200 Hondasaki Hybrid
  #6
Old 06-27-2009, 10:19 PM
arjay's Avatar
Subscriber
Thanks for the feedback.
The frame is a 1986 KX125, the first of the modern rear linkage style and rear disc brake. The year later they went to a twin down tube to accommodate the centre exhaust port. So this is the latest 125 frame you can drop the C series 200 motor into.
Because the subframe, airbox and seat is from an 89 KX, there was less space between the headstock and the seat, which meant that a tank had to be built to fit. Also the larger aftermarket triple clamps come back further on full lock.
I try not to think about denting the tank
I tried to keep it slim as possible in case.
  #7
Old 06-27-2009, 11:48 PM
james.keaton james.keaton is offline
Registered
that is some great handy work. very nice
  #8
Old 06-28-2009, 03:39 AM
steve.emma's Avatar
steve.emma steve.emma is offline
Registered
hi there, do you foresee any problems with the pipe being so close to the alloy tank in regards to fuel getting hot in the tank? just a thought from looking at the pics. very nice work tho, the whole bike looks very sharp!
  #9
Old 06-28-2009, 06:01 AM
arjay's Avatar
Subscriber
Thanks. Yep, the tank runs close to the pipe, there's about a 2mm gap at the closest point, and 5mm + for the most part. I was hoping this wouldn't be a problem as the temperature of a 2 stroke expansion pipe isn't excessive, and it should get good air flow. It would be good to get opinions on this. I haven't drilled the mounting holes into the tank flanges yet, so could always mount it a bit higher to increase the gap.
  #10
Old 06-28-2009, 08:36 AM
whenfoxforks-ruled's Avatar
whenfoxforks-ruled whenfoxforks-ruled is offline
Very nice work Arjay! I really like where you are going with this. I would sure hate the 2mm clearance being too tight, you matched the angles so nice between the triple clamps and pipe, I am pretty sure I have seen tighter? I am thinking along the same lines with my rm370. And am really liking the idea of the shrouds directing air atop the motor. Hopefully I will not have to make a new tank! But, now I may know a guy?
WHEN IN DOUBT, GAS IT!
Reply
Search this Thread:
Advanced Search
General Reviews For Sale Ride Thumpers MX / SX Chapters Suspension KDX What Bike?
Copyright 1999-2005 DirtRider.Net
Dirt Bikes , Motorcycles, Motocross , Supercross , Off-Road , GNCC, ISDE, MX1, MX2, MX de Nations, Dirt Bikes, Trail Bikes, MX Photos, CMRC, Racing, Desert Racing, Arenacross, MX Video
Motorcycle Parts, MX Gear, New Motorcycles, Used Motorcycles, Honda, Yamaha, Kawasaki, Suzuki, KTM
