DirtRider.Net DirtRider.Net Dirt Bike - Motocross - Supercross Forum
The Forums at DirtRider.Net
Go Back  Dirt Rider . Net Forums > Bike Info By Brand / Type > 2-Stroke Discussion > Canadian Daves JustKDX
User Name
Password
The Tactic Of Speed Shifting
Reply
Thread Tools Search this Thread
Old 06-29-2009, 11:22 AM
duke duke is offline
Registered
I was wondering if the tactic of speed shifting, basically acclerating through the gears without backing off the throttle, is harmful to a KDX tranny. Its a common ploy used in racing MX and hare scrambles. I would reserve its use to those rare instances when I plan venturing to a vet track or racing friends along the fire roads.
Old Related Info / Links
  #2
Old 06-29-2009, 11:27 AM
_JOE_'s Avatar
_JOE_ _JOE_ is offline
Subscriber
Just tap the clutch when you shift and you won't have to worry.
------------------------------------------------------------------ « t a g » -----
I think my Throttle of Life is stuck WFO!!!
  #3
Old 06-29-2009, 11:54 AM
james.keaton james.keaton is offline
Registered
my '89 has always been speed shifted...no problems yet
  #4
Old 06-29-2009, 12:10 PM
julien_d julien_d is offline
Registered
the kdx tranny is your regular constant mesh type. Speed shifting should have no ill effect until that one time you miss the shift and hear it GRIIIINDDDD. As long as you are good at it, it shouldn't cause a problem. My fingers are always on the clutch anyway, so I almost always use it.
  #5
Old 06-29-2009, 08:16 PM
23jayhawk's Avatar
23jayhawk 23jayhawk is offline
I know this makes me older than Methuselah, but I recall reading an article by Gunnar Lindstrom in Dirt Bike somewhere around 1974 or so on shifting. Basically, he said you never touch the clutch on an upshift, just WFO but you back off the throttle for a split second just as you shift, which helps the gears slide into position. Really just enough to unload the pressure on the face of the gears and then back on the gas.
Ken W.
  #6
Old 06-29-2009, 09:41 PM
sr5bidder sr5bidder is offline
Registered
i only use the clutch for starting out or feathering for power and some downshifts when the engine is loaded
  #7
Old 06-29-2009, 10:11 PM
Registered
Thanks all. BTW, check out the latest issue of Dirt Rider for a small write up on the KDX; They site the bike's merits and deem a good value today
  #8
Old 06-30-2009, 10:30 AM
Bezoar Bezoar is offline
Registered
Which month is the KDX article in? I could not find it.
  #9
Old 06-30-2009, 12:24 PM
mudpack mudpack is offline
Registered
Quote:
That would be my definition of power shifting.
Shifting quickly, while using the clutch; I call speed shifting.
Shifting without backing off the throttle AND not using the clutch is nearly impossible with constant-mesh gearboxes.
Will power shifting hurt the gearbox? It won't do it any good, but you probably won't experience failure because you do it(properly).
Mud
  #10
Old 06-30-2009, 04:52 PM
KDX AL KDX AL is offline
Registered
Ha Ha Ha Ha
Reply
Search this Thread:
Advanced Search
General Reviews For Sale Ride Thumpers MX / SX Chapters Suspension KDX What Bike?
Copyright 1999-2005 DirtRider.Net
Dirt Bikes , Motorcycles, Motocross , Supercross , Off-Road , GNCC, ISDE, MX1, MX2, MX de Nations, Dirt Bikes, Trail Bikes, MX Photos, CMRC, Racing, Desert Racing, Arenacross, MX Video
Motorcycle Parts, MX Gear, New Motorcycles, Used Motorcycles, Honda, Yamaha, Kawasaki, Suzuki, KTM
