DirtRider.Net DirtRider.Net Dirt Bike - Motocross - Supercross Forum
The Forums at DirtRider.Net
Go Back  Dirt Rider . Net Forums > Bike Info By Brand / Type > Pit Bikes & Mini's
User Name
Password
Back wheel problem.
Pit Bikes & Mini's
Reply
Thread Tools Search this Thread
Old 07-25-2010, 01:19 PM
Corson Corson is offline
Registered
Back wheel problem.
Hey, Im not even sure if this is a problem but I had the wheel bearings replaced on my cr85 about a month ago, and I tightened the chain today and when i was done i realized i could move the back wheel from side to side the slightest bit. I thought I read somewhere that if theres any movement that you need new bearings. So Im just wondering if the wheel can move the tiniest bit its Alright.
Old Related Info / Links
  #2
Old 07-25-2010, 04:15 PM
eagles22793 eagles22793 is offline
Registered
Send a message via AIM to eagles22793
I had a 2002 cr80 and the back wheel was tight after I replaced the wheel bearings in the rear. Did you replace the sleeve in between the bearings or just the bearings.
  #3
Old 07-25-2010, 05:09 PM
ellandoh's Avatar
ellandoh ellandoh is offline
dismount art student
you have to take the wheel off and find out whats loose and repair, it will only get worse and damage other components.....brakes, chain guide, etc.
check the bearing retainer
------------------------------------------------------------------ « t a g » -----
if you're gonna do something you'll regret in the morning its always best to sleep in
if my ex-girlfriend was half as dirty as this president there wouldn't be an ex in her name
  #4
Old 08-02-2010, 09:56 AM
Matt90GT's Avatar
Matt90GT Matt90GT is offline
Registered
Send a message via Yahoo to Matt90GT
all good suggestions.
Also if you do not grease new bearings, they wont last! Remove the rubber seals and pack them with grease
But inspect the spacers and the center sleeve also.
check for loose spokes also
#861
  #5
Old 08-02-2010, 10:05 AM
Patman's Avatar
Patman Patman is offline
Pantless Wonder
Don't remove the rubber seal if you bought sealed bearings as they come pre-greased and doing so will only let ware & grit in faster.
"I ride, therefore I crash." - Patman ~~~~ "Do or do not, there is no try!" - Yoda
  #6
Old 08-02-2010, 10:47 AM
IndyMX's Avatar
IndyMX IndyMX is offline
Dude with a job..
Quote:
Err, if you have ever taken the seal off, you'd know there's hardly any grease in them when new.
I just did wheel bearings in my flat tracker, the new bearings were bone dry on one side and hardly any grease on the other.
They would have been junk in no time if I hadn't opened them.
Just make sure you replace the seal when you have them packed with grease.
  #7
Old 08-02-2010, 10:53 AM
Wolf's Avatar
Wolf Wolf is offline
doooode
I have to side with Patman on the sealed bearings...I have opened them up in the past and yes, they were greased, and no, once I replaced the seal it wasn't a good seal anymore. Additionally, grease or no grease, this should not have anything to do with the play in the rear wheel...something is definitely wrong there.
AAAAHHHHHHHHHH!!!!!!!
www.carpetcleanrx.com
www.ammg.net
  #8
Old 08-02-2010, 11:42 AM
ellandoh's Avatar
they dont have a lot of grease in them for a reason. my unmodified sealed bearings lasted 5years, maybe im lucky. they probably didnt have alot of grease in them either. i know theres quite a few machines at work you have to meter the grease on a tight lubrication timetable as overgreasing will cause the seals to fail
Reply
Search this Thread:
Advanced Search
General Reviews For Sale Ride Thumpers MX / SX Chapters Suspension KDX What Bike?
Copyright 1999-2005 DirtRider.Net
Dirt Bikes , Motorcycles, Motocross , Supercross , Off-Road , GNCC, ISDE, MX1, MX2, MX de Nations, Dirt Bikes, Trail Bikes, MX Photos, CMRC, Racing, Desert Racing, Arenacross, MX Video
Motorcycle Parts, MX Gear, New Motorcycles, Used Motorcycles, Honda, Yamaha, Kawasaki, Suzuki, KTM
