DirtRider.Net DirtRider.Net Dirt Bike - Motocross - Supercross Forum
The Forums at DirtRider.Net
Go Back  Dirt Rider . Net Forums > Bike Info By Brand / Type > Canadian Daves JustKDX
User Name
Password
I cant get my shock out!
Reply
Thread Tools Search this Thread
Old 01-09-2011, 07:24 AM
Fatherof2 Fatherof2 is offline
Registered
I unbolted it without a problem, but I just dont have the clearance to pull it out of the frame. I am using Cyclepedia, and it says to just un-bolt it, and pull out on the right side. I cant pull the top of the shock back far enough to clear the mount that the top of the shock mounts to. Do I need to pull the air cleaner duct to have enuff room? Cyclepedia says nothing about that, so I am wondering if I am doing something wrong. It should be simple I would think.
Thanks for any advice,
D.
Old Related Info / Links
  #2
Old 01-09-2011, 10:53 AM
wake_rider's Avatar
wake_rider wake_rider is offline
Registered
If you could post a picture, I'm sure that would help.
I have always removed the subframe to do any work to the rear suspension. If you haven't already, pull the subframe and I would assume you would negate any further clearance issues.
------------------------------------------------------------------ « t a g » -----
Weekend Warrior
Norman, Oklahoma
  #3
Old 01-09-2011, 11:07 AM
Registered
Forgive me Wake, but what do you mean by "pull the subframe"?
I removed the nuts and bolts that secure the tie rods to the rocker arm and swingarm. I just cant get the damn shock out. I am moving the swingarm all the way up and down. But that is not enuff. Do I need to rotate the spring as I try to pull the shock out? I could really use some advice.
Thanks for any input,
D.
  #4
Old 01-09-2011, 11:35 AM
wake_rider's Avatar
Registered
Ah, I just realized that I'm posting in the KDX forum and I believe KDX's have a non-removable subframe. In this case, forget my previous advice. I apologize!
When it comes to the procedure of pulling the shock on a KDX, I have no experience so I am of no help.
  #5
Old 01-09-2011, 12:06 PM
wake_rider's Avatar
Registered
Have you tried moving the spring up further on the shock to allow a lower setting? I would use a piece of masking tape just below the top of the spring collar to mark your spring position, then try moving the spring further up the shock and see if that gives you a little bit of extra clearance. Again, I might just be throwing solutions completely incorrect, but I'm not able to see what it is that you're having the issue with and I might not be understanding similarly what it is that you're explaining.
  #6
Old 01-09-2011, 01:49 PM
Registered
Wake,
Thanks for the input. Turns out that Cyclepedia left out a few very important steps. I need to take the expansion chamber off, and quite possibly the airbox. Who knew!
Oh well,
Thanks again,
D.
  #7
Old 01-09-2011, 03:42 PM
whenfoxforks-ruled's Avatar
whenfoxforks-ruled whenfoxforks-ruled is offline
On line repair, at cyclepedia? Says who? Unless Rich or Eric fix that site, what next. I will stick with a shop manual. Vintage Bob
WHEN IN DOUBT, GAS IT! : 83CR480R, 97CR250R, 00CR250R 05CRF450
  #8
Old 01-09-2011, 04:59 PM
sr5bidder sr5bidder is offline
Registered
for shure take the air box out and maybee even the left frame bar
  #9
Old 01-12-2011, 07:31 AM
Registered
I took the expansion chamber off, and the shock came right out! Neither the manual nor cyclepedia had the procedure right. No big deal. Just putting it out there for future reference.
Reply
Search this Thread:
Advanced Search
General Reviews For Sale Ride Thumpers MX / SX Chapters Suspension KDX What Bike?
Copyright 1999-2005 DirtRider.Net
Dirt Bikes , Motorcycles, Motocross , Supercross , Off-Road , GNCC, ISDE, MX1, MX2, MX de Nations, Dirt Bikes, Trail Bikes, MX Photos, CMRC, Racing, Desert Racing, Arenacross, MX Video
Motorcycle Parts, MX Gear, New Motorcycles, Used Motorcycles, Honda, Yamaha, Kawasaki, Suzuki, KTM
