| The Forums at DirtRider.Net |
Forks or Shock which is more important?
Suspension Q&A with Jeremy Wilkey
07-21-2001, 03:31 PM
Owner, MX-Tech
Ok here is the first REAL poll. I have found that many riders tend to isolate the front as the part of the suspension that makes the most diference to ride quality. Many of you might know how I feel but I'm intrested in your exsplanations. So file out the survey and post a reason if you like!
07-21-2001, 09:35 PM
Ortho doc's wet dream
my only experience with what i consider to be awful suspension...i bought a new '90 honda cr 250 back in '89. the suspension was so bad it was almost unrideable. people laughed at me until i let them ride it, then they agreed. i sent it off to pro circuit. the shock came back with a night and day difference. the forks i couldn't tell any difference at all. but with the shock fixed, i instantly became a contender on that bike. the forks didn't really seem to matter that much as far as overall track speed.
07-21-2001, 09:41 PM
Lifetime Sponsor
I can confidently break traction on the rear and never have it cause a crash (at trail speed). I can vary the load on the rear with throttle.
The front end needs to afford predictable traction or I am off the edge or in the bark. I can not apply more or less throttle to the front wheel.
And finally, my sissy wrists don't care (much) what the shock is doing.
Of course when I get that cheese valve in the shock my opinion may change.
07-21-2001, 10:12 PM
AssClown Leader
I voted that I "Feel" the forks are most important but I suspect that in theory the forks and the shock are equally important. The forks play a huge part in what is transmitted through your wrists, arms and shoulders so you feel their input at all times. I am betting, however, that the shock plays a much bigger part in the stability and controlability of the bike than we realize.
Am I close to right? Are there any right/wrong answers to this?!
07-22-2001, 07:25 AM
Subscriber
I voted for "Where's C" because IMO if both ends don't work you're in trouble.
07-22-2001, 10:33 AM
Sponsoring Member Club Moderator
You have to have balance. However, the rear end must remain in contact with the ground to have tractablility. Without that, you are just spinning your wheel.
------------------------------------------------------------------ « t a g » -----
Member of an angry mob, TAXPAYERS!
07-22-2001, 10:48 AM
Feel the forks more but BOTH are important.
07-22-2001, 12:51 PM
Registered
I would say the shock for me.
I only ride MX, and much of the time I'm on the throttle hard. The forks make zero difference here. Bad forks may feel a bit harsh when hitting bumps, but I assume make no difference in lap times on that part. A bad shock might make me lose control and cause me to let off the gas.
I'm not saying that the forks are not important. They make a difference in braking (I'm too bad a rider to take advantage) and in turns where you have to slow down or be on non-full throttle for a while.
My forks are shot (the mid-valve, probably) making them extremely harsh since they are most of the way through the stroke most of the time. I tried a friends YZ426 and man what a difference in plushness even with the thumpers fork compression set to 2 clicks out.
My shock is also valved too soft for my weight and bottoms regularly on big hits but works ok on small ones.
Both ends will be done when my vacation is over.
07-22-2001, 07:09 PM
Subscriber
Of course I agree witht the BOTH sentiment, but I voted for the forks. If the shock is a little off (as long as I can set the rebound damping) I don't worry too much about what the back end is doing. But if the front doesn't track, I crash. And when you finally hit one of those whoops wrong at speed, and sooner or later you will, if the fork doesn't absorb the impact well enough it becomes endo time.
Touring 07 Yamaha RSV
street 03 Kaw ZR-7s
dirt 03 KTM 250sx
07-22-2001, 07:53 PM
Registered
I can feel what is going on more with the forks, But I think the shock is actually more important. The shock can affect the action of the forks a whole lot more than the fork affect the shock. Not only do shock adjustments affect traction, but the also have an impact with the way the forks react to terrain. If you change the shock's sag, compression, or rebound setting - you're going to feel a difference up front.
| Thread Tools |
Search this Thread |
General
Reviews
For Sale
Ride
Thumpers
MX / SX
Chapters
Suspension
KDX
What Bike?
