Originally Posted by Vic
Starting with a 250 two-stroke, how close could you come to simulating the powerband of a 250 four-stroke if you were willing to limit peak power to that of the four-stroke?
Does it require a custom pipe and/or ignition curve?
Did you ever have your CR on a dyno? |
What would you estimate the peak HP of your CR to be?
Originally Posted by Okiewan
About 92.
Originally Posted by Rich Rohrich
No and No
A pipe and ignition curve designed specifically this type of engine would certainly help but they are far from necessary. You can do an awful lot with time/area changes and compression ratios on a big bore to get this type of power. |
I was just wondering what you had to give up to get that type of power.
Originally Posted by nephron
Damn, Rich. I didn't know you owned a butt dyno.
Originally Posted by steve125
One big suprise was the airbox side intake boot, we did runs with it attached and with it removed. It was one of the largest changes on the dyno all day. With the boot removed, we lost .5hp on top and about 400rpm of over-rev. Seems this air direction thing(moving straight and forward) is a big deal at high rpm.
, I'll pass, on testing it this time around.
The real scary part is now they have a new PN system. This one has the carb bell section as we have seen. In addition it has a wing in the front of the carb as well, the slide is now in the middle of the 2 blades.
Vic - the torque will peak at a lower rpm, and it won't have the ability to carry the torque curve as far past the torque peak. In other words they will tend to flatten out at high rpm.
