Front Rotor Moves
Posted by: bcVulcan---------------------
I noticed that my rotor has a little play in it where the inner part in rivited to the outer part. Just a little. Is this normal? Why is it made that way anyway? It seems like it would have been cheaper and stronger to make the rotor one solid piece.
Posted by: JasonWho---------------------
Posted by: jnugent---------------------
Mine does the same thing. It's a floating rotor, it's a good thing.
Go to http://www.rockymountainatv.com/home.asp?sid=0003040461 and search under "Rotor". Then scroll down and click on "Titax Oversized Brake Rotors - Kawasaki "
There's a picture of a rotor very similar to mine. What exactly is the purpose of this and is a little play normal?
Posted by: YZ165---------------------
Slight play is normal. It helps ensure proper alignment of the rotor to caliper.
Posted by: kdxman15---------------------
i thought the little bit of give was ment to improve the feel of the brake and all the h models come with the flooting disk.
