CRF-Bog when bottoming out suspension
Posted by: Casper250---------------------
A couple of times when trying to seat bounce my bike, I would get a slight bog when I gas it. There is this double-double at this track that I ride where i jump the first set, then seat bounce the second. When I'm about to gas it at the second jump, my bike bogs for a spit second.
Some one mention that the BK mod would help this but I was just wondering if anyone else has had this problem?
Posted by: GrndPounder---------------------
When you are just idling along and whack the throttle, does it bog? or does it only do it on the seat bounce-double double? If it works fine when you whack the throttle, you might have a float level issue. Check that out.
If it bogs when you whack the throttle, you might try dropping the needle one clip, and if that doesn't help, try going to a different leak jet.
