Originally Posted by John Harris
Good idea. What does one of the meters cost from Yamaha? How is the meter powered or rather how does it get the input to measure the hours? See I am uninformed or rather dense! Thanks John
Originally Posted by JasonWho
Hi. Thanks for that article. That is very interesting, and you did it at exactly the right time. How much did your bottom end rebuild cost?
Thanks. |
Originally Posted by gwhII
Hey, John--I know the feeling. :-) BRush, thanks for the link to SenDEC. Their FS500 gadget looks good in that it also provides a tach. That may be handy.
Best, Greg |
Originally Posted by BRush
There's also a cheaper one that does a tach as well, it's the 806-100-1032. It's about half the price of the FS500.
http://www.sendec.com/meters/html/80610x.html If I was going to shell out for the FS500, I'd probably kick in the extra $20 and get the FSA600 since it's the same size and has an hour meter, 16000 rpm tach, service time, and resetable job timer. |
I saw that one too (-1032) and unless I'm misunderstanding the description it's for a 4-stroke application. .
I admit to being puzzled by that too. It says 1 spark = 1 rpm, so why wouldn't it work on a two stroke? Similar panel-mount models (805-100-0222) indicate 1 spark = 1 rpm and the descriptive text reads "Hours/Tach, for most single and twin cylinder engines, 2 or 4 cycle" so I wonder if it's an inadvertent omission on the -1032?
