01 YZ250 frount fork springs
Posted by: sdkinion---------------------
I have a 01 YZ250 with stock fork springs .43. I ride mainly woods in the NC mountains. I weigh 225. I just had the forks serviced and revalved and they are still too harsh. I have been bouncing off rocks, roots and holes. I have been running only about 10 lbs of air in the front tire. I have tried adjusting the compression and rebound. What spring should I change to? Any other suggestions.
Thanks for your help.
Posted by: dbrace---------------------
Did your tuner not suggest springs??
The first step in setting up suspension is getting the springs dialed in for your weight. Depending on your height i would suggest .45kg fork springs and approx 5.4kg shock spring. This will hold the suspension up in the stroke and if the valving is done right provide you with a plush ride.
Regards,
Darren
www.dbracesuspension.com.au
