Which exaust FMF or pro circuit?
Posted by: yankeefan4life72---------------------
I have an 05' Kdx 200 and I want more power! Iwanted to increase the whole power range but I see fmf and pro circuit both only have the gnarly and it only increases the bottom to mid range with a little loss on top.Please help!!!!
Posted by: KDXFreestyle---------------------
The FMF's dont fit right (most of the time) and have the worst support. The best choice woul dbe pro circuit. The Platinum Pipe will give you more hit in the midrange and increase midrange to top end. The Platinum 2 will do just the opposite. be smart. Go with a pro circuit.
Icant get a platinum pipe for an 05'only a platinum 2. I talked to jeff fredette and he recommended a fmf gnarly.What to do?Thanks for the response
Oh yeah I forgot to tell you I do a lot of track and trail riding so I guess I want low to mid power anyway right?What to do?
Oh, what is the difference between the FMF gnarly woods and the FMF gnarly desert pipe?
desert is th emidrange to top end,and the woods is bottom to mid. Yes you can get a Platinum. it is the sam epipe as the 95-05's. Same with the platinum 2. The platinum )mid to high) will give you a good hit with some bottom end. the best way i can describe it is a 125 with a midrange hit, and also with bottom end. This will also depend on your gearing. whatever you choose, you will be happy.
