Originally posted by JTT: ...and is there an easy way to determine if it is MTBE based? (ie; special labeling, etc) |
What would you recommend for a person like myself with both a 2 stroke (ktm 300) and a 4 stroke (yz426)or is their not one fuel for both.
Originally posted by Rich Rohrich: - Mixing alcohol based pump fuels with ANYTHING in an attempt to make it BETTER is just a chemical circle jerk, and if you're that cheap or that ignorant you deserve the crummy performance and the insurmountable jetting problems that you will invariably be blessed with. |
| when I mix oxygenated fuel (Oct - Feb it is sold here for pollution control - per the verbage at the pump) with the Sunoco |
Originally posted by Strick: Rich, in all candor, I have never used straight race gas. What I was getting at above is: the winter blend (oxygenated) gas when mixed with the Sunoco (110-purple) race gas seems to perform better than the normal (non-oxygenated pump gas). |
Originally posted by Strick: The local bike shop that sells VP, says that Sunoco's 110 rating is bogus, and the VP rating is correct. For what that's worth! |
Originally posted by Strick: So of course I am curious, what fuel is going to make the 'ole 300 a fire breather?? |
| Good luck trying to get them jetted clean |
Originally posted by KawieKX125 Rich, does that comment mean that Mobil gas is hard to jet |
Originally posted by Jim Crenca Lastly, is it fair to say that plug heat range is decided by riding type & not fuel type? |
Originally posted by Strick Rich; Thank you very much for the detailed answer. I do think I will experiment, like I did a few months ago with gear box oils |
Originally posted by VOR 492 Rich, My Local Marathon station Sells CAM 2 110 Octane race gas, is this good Gas for my VOR? I pay $3.00 a Gallon. |
Originally posted by Jim Crenca Hey Rich, You never responded regarding my gross generalization statement which was: * If you have to use pump gas use Amoco premium without ethanol blending agents (although a dealer told me as of June 1 MTBRE won't be allowed in MD) |
Originally posted by Jim Crenca * Avgas is better than pump fuel |
Originally posted by Jim Crenca * Race fuel from the dragstrip is probably only good for wide open throttle applications |
Originally posted by Jim Crenca * A good readily available fuel for general purpose riding is VP C-12 (about $8 per gallon here) |
Originally posted by Jim Crenca * Any generalizations on jetting from pump to race fuel? |
Originally posted by new hampshire hick i was told that leaded gas runs cooler then unleaded, is this true?? |
Originally posted by Dirty Dave Rich, here in California we are pushing the state gov. to hurry up and remove MTBE as the oxygenate of choice because it is a known carcinogen. According to tests the cancer causing agents are unaffected by the combustion process and come out of the exhaust pipe in the same chemical form as it came out of the pump nozzle. |
Originally posted by Jaybird Should I start concentrating on jetting instead? I'm very ignorant on jetting...is it time to learn? |
Originally posted by RM250Rida Lower octane gas burns hotter, easier, and faster. So you may wonder, why do they produce higher octane gas, if it causes slower combustion and cooler burning. |
I expect far more from my friends than random strangers.
vBulletin Copyright ©2000 - 2013,
vB Easy Archive Final ©2000 - 2013
