Originally Posted by terry hay
Has anyone else noticed the problems associated with bleeding the KYB twin chambers? They're not quite ready to take on the Showas just yet.
Terry Hay |
...and I had already added 10cc prior to draining at the track....the factory spec is 245cc, If I would have known this I may have not needed to go up 1 rate with the springs?
Originally Posted by russ17
As I stated James this was my personal opinion with the modifications. And you are correct in your statement without the modifications. This was just my opinion. I like the feel of the KYB T/C
Restated, my comment could read: I would gladly take Showa performance over the current unmodified KYBs and be happy.
What is it they say....the best you know is what you have ridden or something like that???
Originally Posted by bclapham
i was always under the impression that the showas were actually a separate system, but after talking to a friend, i discovered it is constantly circulating- i thought i had bad cartridge seals when running different oils in the inner and outer chamber- one oil was red, but both fluids came out red a few weeks later!!! i now run the same oil in both chambers, its good since we can make simple valving changes at the track and keep oil levels etc essentially the same.
Originally Posted by brentl
Any comments on my question about the 06 "speed sensitive" forks...Think they might help with the front end pushing?
I've raised my tubes 12mm btw Thanks for any info!!! |
Originally Posted by lemons r yellow
very informative Terry.
Thank you Where do you drill the 4mm hole in the piston? |
