Need KDX 220 Crank part!
Posted by: Rob in AZ---------------------
I lost a piston skirt on my KDX and the broken piece cracked one of the plastic stuffing blocks bolted to the inside of the RH crank half. The part is only available on the crank half (173.00). Hoping someone out there has a junk crank with good stuffers. Any help would be much appreciated.
thanks,
Rob
Posted by: Colorado Mike---------------------
Man, that's sad news. Sounds like another case of 220 piston breakage that Kawi says is not a problem. You might try calling Jeff Fredette, I hear he has a lot of used parts. Don't even think of putting a stock piston in it.
Good Luck,
Mike.
Posted by: KelvinKDX---------------------
If Jeff does not have it i would suggest calling Eric Gorr.
