cam on xr650r 2002?
Posted by: porttiming---------------------
Does anyone know a good cam for xr 650r 2002?
i install intake from honda and yoshimura rear exaust.
anyone knowing if porting the head is good modification on this engine?
thanking you in advance.
megacycle has some great rfvc cams.
Depending on your desired power delivery, peak power, and reliability desires will determine their best grind for your application.
If you want a real cam you will need shortened guides and a spring kit.
I would also have the head set up by a pro.
The rockers will need inspection as well.
Any real RFVC motor I have built includes a piston and a Carrillo rod as they tend to stretch the small end when they a caned thoroughly.
