Eric or Rich about V Force
Posted by: motolink---------------------
I was reading an old thread about the V Force 3 in the 04 RM 250, it said when using the V Force 3 in that model it will partly block the transfer ports unless you use a spacer to move the V Force 3 reed cage backwards about 6mm. Is that correct. I beleive the spacer from the 05 YZ 250 does the job.
Does anyone know, thanks
Posted by: steve125---------------------
What blocks the rear boost port is the std reed pedal stops. The V-3 does not use the pedal stops. But both reed blocks do benefit from the YZ reed spacer and it measures 4mm thick.
With the V-3 and the YZ spacer you will notice a better throttle response, a very crisp, but smoother transition(reed spacer), into the power band and better over-rev.
The only jetting required will be to fine tune the pilot circuit, via jet size or air screw setting.
Steve, thanks, I have purchased the spacer and will have it in on the weekend for a test.
Posted by: Spoolin---------------------
I just picked up a set of VForce 3 reeds for my 01 KX250. Haven't had a chance to ride it yet, but I was wondering if other bikes, besides the KTM, could benefit from the reed spacer on the YZ.
Posted by: highflyernick---------------------
Sorry to high jack the thread but ^^^^ Spoolin, post a ride report on it after you have them in. I have a 2001 KX250 and was thinking about getting them. It would be nice to see the difference first.
