Triple Clamp Change
Posted by: ronhawker---------------------
Is there another triple clamp top or similar that puts the bars straight across the top like most bikes rather than pushing the bars back? This is on a 1990 model.
The stock triple clamp angles the mount back towards the rider. I would rather have the bars directly on top with the mount straight up so the bars are more forward. I am running Tag fat mount and fat bars and that really cramps the reach and pushes me back. I can't over the front as much as I want to.
Another issue is the design of the oil drain bolt. What was Kawasaki thinking with the case design where there is a ridge right next to the oil drain bolt. Any standard flange bolt is too big and hits the case machine edge and leaks. It seems only the exact diameter bolt with work.
Thanks Ron
Posted by: lepper---------------------
You can use a 95 and up KDX top triple clamp... no problem!
