Originally Posted by WhiPit
You don't need to wrap the threads in teflon....just push the rod through. And "yes", the shaft with the short spring is where your compression valving is located.
Originally Posted by Miedosoracing
Like I said, you have no need to take the rod from the cartridge. I think that is where our lines are crossing. The rod and the cartridge can stay in tact. You just take the inside out of the cartridge. You never need to get down to the rod of you are just reshimming... Only if you are gonna fool with the spring, seals etc. Not the valving for the compression assembly.
as far as what I did on my Honda 00 250 for my first time reshimming it, I just took out the seperater shim in the middle of the stack, and it made a world of difference. I don't do 2 stage stacks.
Originally Posted by tx246
yall,
i know this is a stupid question but i really have used the search function to no avail. where are all of the shims/midvalve located in the fork? im talking about TC showas off a 00cr250. ive taken the forks apart as far as the manual goes. this will get a seal job done but thats it. from info gathered here, it seems high speed compression is too stiff. ive backed the compression clickers all the way and noticed no difference at all. it seems on hardedged ie rocks, the suspension doesnt react at all. i know im not going to get it perfect do it all performance but would like the clickers to move and me be able to tell a difference. ive had this bike for three years and after this last trip to moab, im sick of tired of getting hammered by the forks. i ride 80woods20mx. this is the first bike ive ever had that i couldnt bottom the fork. that is great for the wrists but thats about it. with gear im 200 and have the sag set where the bike handles great. when forks were apart last time, the cartridge on both forks reacted fine after refilling and bleeding them. thanks for reading |
Originally Posted by James
Which shim is the "separator" shim on the compression stack in the 2000 CR250 fork?
Mine had a seperater shim, small 12 I think it was, right in the middle. I figured it was stock, because the bolt was piend on still from factory, unless someone changed it, and repiend it.
. i was afraid i was going to get a pinch flat on the front tire because i was slamming into stuff. good times. i was afraid the front would get wallowy but it didnt. i cant wait to take it to the track. i think braking bumps will be much better with this set up.
