MXA Yamaha did away with the Kayaba AOS (air-oil-separate) fork and came up with a new S³ (Speed-Sensitive System) designed 48mm fork. The damping force is controlled by piston speed rather than the position of the fork. The different feel of this type of suspension might seem too soft, initially, but the all-new fork is said to feature better bump-absorbtion and improved comfort. |
Originally Posted by steve125
’05 generates secondary damping from cylinder piston penetrating the plastic TCV located below the spring.
The interaction of piston in plastic cylinder (kind of mild oil lock) makes the secondary damping dependant on the position of the fork. For example….deep in the stroke damping is high. ’06 secondary damping comes from restricting the flow of oil past the main spring and spring guide, therefore the damping is based on the speed that the fork is compressed; the speed the oil is forced up thru this restriction. For example….deep in the stroke equal same damping because damping force only increases with speed of fork compressed. |
