Clutch Kit Options: DPK or EBC
Posted by: rbaker---------------------
Hey Guys,
Its time to put a new clutch in my GF's Honda CR80.. anyway i was wondering on which set to go with.. I want something that wont be super stiff for her but i also want it to be able to take some abuse from a rather newer rider.. the funny thing is that she didnt even burn it out.. one of my idiot friends did! Stock is an option as well if you guys think that will work well.
Here are the options:
DP Clutches DPK Clutch Kit
EBC DRC Race/HeavyDuty EP Kevlar Series Clutch Kit
DRC Series Clutch Kit
Thanks Guys,
rbaker
i went with the DP kit.. ill post my opinions when i get it and install it.
~rb
Posted by: allUseeisRoost---------------------
i just got the dpk clutch discs plates & springs kit and a motion pro clutch cable for my cr... it slides a little easier than stock and im noticing less aluminum color in the oil when i drain it...
Posted by: whenfoxforks-ruled---------------------
OEM Honda fibers with steel drive plates, the best option. Check out Service Honda for a clutch kit. How are the hubs, any sharp edges from spinning? Any new clutch pack in bad hubs will not last long. Any notches in the basket or inner hub? I hope your friend is footing the bill?
Posted by: FruDaddy---------------------
DP has steel plates, and you apparently don't need to soak the frictions before installation. In fact the documentation says that you can install them right out of the box and ride. I will be installing them tomorrow.
vBulletin Copyright ©2000 - 2013, Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2013 - Created by Stefan "Xenon" Kaeser
