220with desert pipe. is it usable on the trail
Posted by: the trail rider---------------------
I am going to buy a fmf pipe and want to know is it possible to use the desert pipe on the trail and still have plenty of low end. I plan to rejet use a torque ring and add boyesen reeds with the air box mod. anything would be great
Posted by: Mrobbins---------------------
I have the same set up minus the torque ring and it is great for single track.
I forgot to mention that I am going to run a 12 tooth in the front instead of the 13 to help out power
Posted by: Green Hornet---------------------
Mine works great. Still has low rpm torque
Posted by: Aflica---------------------
one word for ya "YES" , its still got great bottom, i used to have the woods pipe....hated it and went for the desert...love it
Posted by: Zerotact---------------------
I have a Pc pipe, with stock gearing. And my friends joke abouit never hearing a 2 stroke being luged at such a low rpm.
Posted by: Rhodester---------------------
Sounds like a good set up. I'd lose the torque ring though...put the 10 bucks into synthetic premix oil.
Posted by: KdxChode---------------------
yea, what he said... Everyone who rides my bike with the rev pipe says it's just like riding a four stroke.
thanks guys but I want to know will it be okay to ride it on tight technical trails or will I get thrown off the bike or worse go off the cliff.
It's no problem. The bike is still plenty smooth. There is no abrupt power surge or anything. All I ride is tight really technical stuff up here in Oregon. Just take my word for it, the rev pipe works good.
Posted by: Robcolo---------------------
A whole lot depends on the needle choice and its position. If you install a lean needle or are otherwise lean just off of idle the bike can be quite a handfull with a whole lot of instant HP. I had to install steahly's 10oz flywheel weight to tame mine with the rev pipe.[I've a number of other engine mods which all add up to be pretty wicked everywhere in the powerband]If i'm riding really technical/loose stuff I'll also richen up with the airscrew just to soften the hit. Pro Circuits spark arrester further adds 2 or 3 HP.
Posted by: Canadian Dave---------------------
You'll be very happy with the rev pipe on your 220 even in tight nasty trails on the island and will certainly see an improvement over stock from the bottom through to the top end. Don't be fooled by the term "rev" as your KDX220 will still have plenty of controllable bottom end grunt regardless or which pipe you use. The biggest difference is that on the 220 the rev pipe noticeably extends how long the engine will make power at higher rpms with slightly more hit after the kips valves open at 6000rpm over the torque pipe.
David
