2004 Yz250 stock suspension settings
Posted by: yfz450---------------------
Does anybody on here have the stock suspension settings for my 2004 yz250. I really want to know where to start. This bike has massive headshake at both high and low speed. This bike is going to kill me.....any help would be greatly appreciated. Thanks
Posted by: bedell99---------------------
Before you even think about setting clickers go out and make sure your sag is properly set at 100mm.
Erik
Thanks Erik, I'll do it tomorrow. Any idea of the stock settings?
Posted by: Benny477---------------------
On my 03 the stock settings were comp11 reb 11 on forks and comp 12 hs comp 1.2 reb 11 on the shock. I personally would try comp 12 reb10 on fork and shock with hs comp out 1.5 turns and see what happens.
Thanks for the help, anyone else know for sure if the 2003 is the same as a 2004? I know the 2004 has different forks. I read some review when it was released that compression stock on the front forks was 15 clicks out? Thanks again for the help !!!
vBulletin Copyright ©2000 - 2013,
vB Easy Archive Final ©2000 - 2013
