Originally Posted by CaptainObvious
I use the bounce rule. If my head bounced, I'm buying a new lid. Then again, if I just wanted a new helmet, I might make the crash look worse then it really was
Originally Posted by MrLuckey
Be very very careful with those concussions, they come easier and easier and the effects are cumulative!
Originally Posted by Thump
This thread got me thinking.... I have had some pretty good get offs on my Henry replica Shoei over the past 4 years so I figgured it was time to get a new one. Ordered a Troy Lee Designs SE Henry Replica from MX South. Got here yesterday and it rocks!
Originally Posted by schwen_108
I ONLY throw my helmet out if I fall hard enough so the styrofoam in the inside is cracked or broken..
Originally Posted by Masterphil
I like that method. Obviously, If I crash hard enough to have a concussion or a major headache that lasts the rest or the day, A new helmet is in order. I've probably crashed 100 times on the helmet that I'm using now, but not one was what I'd call major.
One common misconception is that hard hats have a predetermined service life--this is not the case. Both the 1986 and 1997 ANSI standards address service life under maintenance and care of the hard hat. Those standards state that all hard hat components should be inspected daily for signs of dents, cracks, penetration and any damage due to impact, rough treatment, or wear. any hard hat that fails the visual inspection should be removed from service until the problem is corrected. In addition to everyday wear and tear, ultra violet (UV) radiation can pose a problem for hats constructed of plastic materials. Damage caused by UV radiation is easy to spot: the hat will lose its glossy finish and eventually take on a chalky appearance. Further degradation could cause the shell to actually start flaking away. Once the effects of UV radiation are detected, the hard hat shell should be immediately replaced. |
Originally Posted by wirefryer#85
And don't throw them away! Either save the washable liners and the visor for your next same brand lid or put them up on the wall so you can tell the grandnippers how ya' almost got wasted but the HELMET saved your ass!
Originally Posted by trial_07
I crashed hard on my head at the beginning of summer and had only a minor concussion so I guess it's all right.
. When would you decide it wasn't any good anymore? Once you have sufferred a head/brain injury?
What happens with your helmet after you have a crash?
So you just dropped about $400 on a new Shoei or Arai. Your first time out with it on and you crash. This crash is a little harder than your normal get up with a bruise or two crash. You might have broken something weak like a collarbone, but your head feels fine. What do you do with your helmet? |
