MID-VALVE STACKS (from the bottom to the nut) Cup washer and spring id6xod10x0.2mm spacer id6xod10x0.2mm spacer id6xod5x0.2mm spacer id6xod8x2.25mm collar (on which the shim stack "floats") COMPRESSION STACK (id=8mm) 4x17.1 6x20.1 PISTON |
Thanks Russ!
Originally Posted by Yoken
Hi fellow enthusiasts,
Although the bike handles well in stock form, it bottoms out pretty easily on big jumps and charging through breaking bumps on lap 5 makes me feel really old (...maybe I am?). Thanks, Yoken |
Interesting remark! Although I don't carry the speed and rage of a pro rider - not even close - I do feel in some turns that the rear end rides pretty low. As long as I keep my body way up front I'm fine. However, when I get tired and my butt moves back an inch or two on the seat (it doesn't take much really) then the rear end sags and I can no longer hold a tight line in the turns. I put that on the account of the stiff BV stack and high oil level. I never thought about going stiffer on the rear spring... I'll see how it feels after I soften the BV.
Marcus, to reduce the preload I backed off the rebound clicker ass'y 3mm on the damping rod. In stock form, the clicker ass'y was threaded all the way onto the rod and that's in that position that I measured 6mm preload. The clicker ass'y is not threaded all the way to the bottom so I figured I could back it off 3mm and still keep about the same thread surface in contact with the rod. Also, I made sure that the small "D"-shape rod (that connects the adjusting screw to the needle inside the damping rod) would not disengage with clickers full in or full out. |
Now to increase preload, I guess the easy way would be to use spacers underneath the spring. But how do you guys reduce it ? I can't think of too many options : - shortening the spring ? - cutting another groove on the cartridge 3mm above the stock one and move the stopper ring up ? ... or do I really miss something ? |
