Cr 250 fork interchangability?
Posted by: cnielse5---------------------
I have a 97 cr 250 and I am wondering about cr 250 interchangability. Will 99 cr 250 forks fit? how about 00-01? or even 02-06? I know that from 97 on they have been showa 47mm twin chambers. Anybody Have any knowledge on this subject?
Posted by: darringer---------------------
Forks from 97-02 at least are interchangeable for sure. It may even be as late as 05. I ran 00 forks on my 99. The valving got progressively better for the aluminum frame in later years. The early forks were brutal in stock form. Re-valving helps considerably.
I was pretty sure the 00-01 would work with the 97-99 bikes. I have chnged the fork oil on 98, 01, and 03 and they are all very similar. My 97 I have never changed the fork oil becuase the top of the forks are different than the 98-03. I sold my 03 cr (because I I bought it for $2500 and sold it for $3500) and I still have the 97 that I am putting a little money into until I can buy another 02-06 cr250. I am really considering having MX-tech do the revalve on my 97 but i am debating dropping $500-$700 into the suspension.
Posted by: Jim Havins---------------------
Externally they are the same from 97 to 05, the only difference being the length of the tubes for those that used a 20" wheel as an option. It has a slighly longer tube but still will work. The 06 is slightly different at the bottom I beleive but would still work. 125, 250, and 450 will interchange, even the Kayaba....
Posted by: jimt_yz400---------------------
You may run into issues with the caliper not being able to mount on the new fork. I was unable to mount an '02 CR250 caliper on a set of '05 CRF450 forks.
Just an FYI
Posted by: oldfrt613---------------------
If I remember right, the length on the '97 is shorter than the '01 ( I had a set of "works" cartridges I wanted to use in my '01 ), in '05-06 the fork has the axel mounting position moved 2mm closer to the steering head ( equivellent to running 22mm offset clamps ) disk will interfer with caliper but can be made to fit. Offset does offer crisper turning. As far as different forks for 20" rim, I don't believe this is correct. Manual shows flush mount tube top for 20" rim and raised position for 21".
Posted by: azmxyz---------------------
The axle spacing is different starting in 02. If putting 02 & newer on 97 to 01 you have to use the newer axle & spacer. They moved the lug closer to the center so they could make the axle shorter witch means a little less weight. The caliper mount spacing is different starting in 04. The bolts are closer together.
OK This is good info. sounds like only forks from 97-01 will be a direct bolt on.
Posted by: bikepilot---------------------
What was ment by the 20" front wheel comment, is that bikes for which it could have been an option (regardless of wether they actually had a 20 or 21" wheel) the forks were 7mm longer. This is to say, 01 forks are 7mm longer than 97' forks. With a 21" wheel one would normally run the forks with 7mm of upper tube protruding through the upper tripple clamp.
