Tripple Clamps
Posted by: +30---------------------
does anyone make a rubber mounted tripple clamp that has four mount bolts for the bars that is adjustable forward, to help stretch out the bike. I prefer the rg3 style four bolt pattern. but they are not adj.forward or aft. the pro tapers have some adjustment to them, do any of you guys have experience with these clamps, do they twist like stockers when you dump it?
Posted by: OldMaiconut---------------------
There is a bit of adjustment on the RG3 clamp. The bar mounts are offset so you can reverse them to push the bars forward about 10 mm. I run them on my YZ250.
thanks,! didnt know about the offset, that should be perfect then.
