Fork Oil
Posted by: MOTOX888---------------------
Does Changing Fork Oil Require Dissasembling The Fork, Or Is It An Easy Procedure??
Posted by: ruddycooter---------------------
Depending on the fork, just remove the cap, drain the oil and replace with new oil.
You don't have to disassemble unless replacing seals. (but, 50% of the time, changing oil will result in leaky seals within a couple months)
Regards,
cooter
