Need help ! i drop my valving on the floor !
Posted by: mxbiker---------------------
Please i need help !
I had to change my shock seal head on my 01'rm250 and i drop the piston and all the shims on the floor and now it's all mixed up. If someone know what the stock order of the shim please let me know.
It's not the first shock that i work on but this time i made a big mistake
A fast answer would be very appreciated since I was planning to ride on sunday. THANK YOU ALL
Posted by: KawieKX125---------------------
You may, if the bike had been ridden alot, be able to see oil stains(I really odon't know how to describe it, it is just markings on the faces of the valves). Sometimes, you can piece the valving together this way. I have before and gotten it right. You just see the dark area, and find a corresponding shim that fits in that area.:think
I wish i could see marks but i only ride it 2 times so the shim are pretty clean...
Posted by: Jeff Howe---------------------
Comp
40 x .2(8)
30 x .1
28 x .1
38 x .25
36 x .25
34 x .25
32 x .25
30 x .25
28 x .25
26 x .25
24 x .25
22 x .3
Reb
36 x .2(5)
28 x .1
36 x .3
34 x .3
32 x .3
30 x .3
28 x .3
26 x .3
24 x .3
22 x .3
That oughta help ya out mxbiker!
Posted by: JTT---------------------
MXbiker, next time try inserting a small piece of wire into the shaft end before removing piston and stack, slide the stack up onto the wire and twist the end into a loop. This way, even if you drop them they stay together and in the right order.
Thanks Shocknut, it will really help me !
JTT thank but this is what i usually do but i didn't this time... thats what happen when you have two left hand and you're right-handed !! :confused:
