Originally Posted by canyncarvr
(d) Wrong nut?
| A tapered thread (say...pipe) would show up some past a thread or two. Consider: If it DID taper that fast, how is it going to make it all the way INto the cylinder? Well, obviously with a tapered thread there, too..but I don't think so. |
It's listed as an 8x32 stud. I've not actually checked mine..but I believe they are not taper threaded. I have a spare cylinder at home. I'll check one of mine if you're interested. |
Shouldn't be any clean-up necessary. Those areas of the cylinder should be well protected during the plating process. |
| Who's doing the replate? |
Sorry...I didn't keep track of this thread.
The studs are the same thread pitch on both ends. I took a spare stud of mine and threaded a nut to the end of the threads on both ends using my fingers. |
Anecdotal info is not the best to count on..and that's what this is: My experience with USC isn't good. I know of other riders that have had a similar bad experience with them. I don't know from personal use who I'd prefer, but I won't ever use USC again. |
USC's point of view: Some cylinder base material is quite porous. Replating leaves pits. Some pits are OK.
They will send you a piece of paper with a lot of specks on it attempting to define the criteria used to determine if the cylinder is good enough...or not. If you don't get that 'documentation', tell them to send it to you. |
so I hope it is above the top ring.
