help
Posted by: smdr 85rider---------------------
i hav a cr85 and it keeps boggen i keep the rpm's up but it still bodds and the choke is on and the gas sooo any sugestions
Posted by: TimberPig---------------------
The choke (more correctly the starting enrichener) is only used to start the bike when cold. Try taking it off. If it gets worse, your jetting is lean and needs to be richened up. If it improves, you were making it very rich by using the choke. Also if your spark plug is black, it is rich.
Posted by: FruDaddy---------------------
You need to take the time to jet the bike. Find Spanky's jetting guide. And close the choke as soon as the bike will idle without it.
vBulletin Copyright ©2000 - 2010,
vB Easy Archive Final ©2000 - 2010
