Replacing water pump on 04 CRF250
Posted by: railin725---------------------
Hi, my friend has a 2004 CRF250 and needs to replace his water pump. Does anyone have recomendations or instructions on how to do this, or where to get the parts?
Thanks in advance.
Posted by: MikeS---------------------
Service Honda or any honda dealer.
Now you say water pump .....
What is wrong? Does he want to rebuild everything related to the waterpump? Is the seal only bad?
It can be a 5 minute job for the outer seal or a good 2 hour job for inner and outer seals and bearings.
The outer water seal can be done by just removing the WP cover. If you need to do the both seals/bearings then you have to pull the side case off. That takes a bit of time 1/2 hour or so, another half hour to clean everything up and replace the parts, then about 1/2 hour or so to button it back up..
