Originally Posted by kdennan
Hey Green Hornet. Let's go ride sometime this summer. I want to check out new stuff and you are welcome to come up to Vt. and check it!
Originally Posted by Tom L
I richer jet needle setting (lower clip groove) or richer main jet will also help low end and not hurt your top end significantly.
Originally Posted by Green Hornet
Correct Cold Air=more air, but higher up contains LESS AIR=Smaller Main,.
OK I confused myself. It make more sense noww ![]() |
Originally Posted by TimberPig
It might make more sense if you think in terms of air density, and oxygen content, instead of volume. At higher altitude, the atmospheric pressure is lower, thus the air is less dense, because there is less pressure keeping it tightly packed together. Lower air density, means less oxygen sucked into the engine for a given volume of air, and thus leaner jetting is needed.
Cold air acts the same as higher atmospheric pressure (lower elevation), in that cold air is more dense because at low temperature, the air contains less anergy and thus is more densely packed together. This causes cold air to also have a higher oxygen content, which requires richer jetting to maintain the correct air fuel mixture. |
Originally Posted by KDX CRAZY
Timberpig
The way I understand the jetting is with the amount of throttle opening not engine speed as you stated . |
