what type of skid plate?
Posted by: rockrider---------------------
What type of skid plate are most of you using? Where did you get it and how much did it cost?
Posted by: buffmaster---------------------
I've got a Utah Sports Cycle off road plate on my KX. So far I like it. I got it from rockymountainmc.com for $55($54.95). I've got a boo-boo near my oil drain hole that had to get welded, and I think that the last time I rode, the plate paid for itself.
BTW, it's fairly heavy duty, covers all the necessaries and has a hole for the oil drain.
Posted by: NDRO---------------------
Their "skid plate" covers only the center section of the frame. It doesn't cover the water pump or the ignition.
I had one on my old CR250 and it was perfect, but the KDX one sux. When I called them about it, they said "there's already a frame loop there". I asked if they had looked at ALL the other plates on the market and the fact that ALL covered the sides, but they didn't care. GGGRRRR:think
NDRO,
Yeah, that is the type of plate I want to avoid. To me that is more of a glide plate then something sutible for off-road. BuyKawasaki offers the same type of glide plate for like $100 for the KDX.
Posted by: justql---------------------
I have Devol on my RMX, it has held up really well.
Posted by: fishhead---------------------
I got a Moose from Fredette and it was easy to install, priced reasonably and has a profile that sticks out under the frame guards on both sides. It's also easy to clean the crude that accumulates between the cases and the guard.
Posted by: swamper---------------------
I purchased one last fall from Recreation Unlimited out of UT. They had three varieties, all cheap (inexpensive). The one I got was the desert model and it is well constructed and covers the the bottom of the pipe! It works well, but if you ride in the mud alot you might consider their cheaper model that just covers the frame and side covers.
Posted by: KDX440---------------------
I'm running a White Bros. purchased from Chaparral....about $65 if I remember correctly. Great coverage including the side "hoops" on frame. Zero obstruction of shift lever, and I've yet to hang my boot up on it. Mounts secure. Drawback...no oil access hole drilled. Drilled my own with a 1" hole saw. Just my two cents.
KDX440
2000 KDX 200
