DRZ400E oil change
Posted by: slammer---------------------
Going to change the fork oil any advise on weight and how much. Do I check the level with the spring out and the forks collapsed. Should I take them apart and clean them?
Posted by: John Curea---------------------
Slammer
Take them apart, only way to get the crud out, it all collects at the bottom right on the base valving.
Yes, the oil level is set with the springs out and the forks collapsed
Note, when turning the forks upside down to initially drain the oil be careful not to loose the rebound adjusting needle and spring. This item is "captured" in most late model forks but not the DRZ Showas. The spring and needle "lives" in the piston rod. The last set I did the customer previously changed the oil himself, when I received the forks the rebound adjuster needle and spring were MIA!! :scream:
Good Luck, Vet
Thanks for that info KXVET, do you also recomend an oil weight.
MOBIL 1 ATF !!!
Try your local Auto Zone, thats is one place that usually carries Mobil.
Take Care, Vet
