ASV Rotator Clamps
Posted by: robwbright---------------------
Anybody have the ASV Rotator Clamps for clutch and brake?
Do they work?
Posted by: Okiewan---------------------
yeah, they work. You can also leave your purches "kinda loose" and they will rotate in a fall.
While not as "trick" you can also wrap some teflon tape around the bar under your purches.
Posted by: soulmate33---------------------
Quote:
Being a plumber, I got sh*t loads of teflon tape laying around which I used under my lever clamps for damage control. This is before they started to use those teflon/plastic collars under the clamps.
On a side note, I use teflon tape on bolts for my seat, all plastics, subframe, exhaust pipe & silencer mounting. It definitely prevents corrosion from electrolysis (steel bolt to aluminum threads). And it kinda acts like a very light duty thread locker. Beats using loctite all the time. Just 3-4 wraps should do it.
I've always left them kinda loose, but still managed to break a clutch lever when the bike fell over - not even riding.
I just wondered if they're worth messing with or not.
Posted by: Gibby---------------------
Buy the levers and never worry again.
Quote:
Got some money I can borrow - those things are pricey.
