Setting cr250 -96 suspension...
Posted by: Kasjok---------------------
I weight 90kg. Maybe someone can explain what should i consider setting my suspension. Which settings should i use, i`m still beginner, so please help.
Posted by: kawamaha---------------------
well, all the bikes are for riders with about 75-80kg. what you need are stiffer springs.
The problem is that it`s a secondhand bike. Maybe there are allready stiffer springs. How can i control if i have stiffer or the original sprins?
on the rear you see it when setting the sag:
www.s#u#per#cross-online.de/Z/sag.htm (delete all #)
