how do you remove needle from slide?
Posted by: Dw-kdx200---------------------
how do you remove needle from slide on a 91 kdx 200?
Posted by: ellandoh---------------------
http://www.dirtrider.net/forums3/sh...0&highlight=6mm
iam having trouble getting the spring out. it feels like its going to break before it pops out. any tips would be very helpful.
Posted by: captbly99---------------------
did you get the cable unhooked? just put a small headed screw driver down there and pop it out. just be careful.
Posted by: robwbright---------------------
I pull the spring back as far as I can, then take a pair of needle nose pliers and grab the cable as close to the spring as possible - it holds the spring back and you can then use the pliers to move the cable around to get it out.
