PDS Oil bypass Spacer
Posted by: rick#3---------------------
Hi Jeremy, is the bypass Spacer tunable within the PDS shock. I have seen some pictures that would leave you to believe it is adjustable for more or less flow depending on it's position within the shock shaft in regards to the bypass hole?
