starts first kick every time but keep a constant eye on things as it is a thumper and they do vibrate and things tend to get loose after time like my plastics i cant keep them tight to the frame as far as my valves go i hadn't had any problems yet but will keep you posted as i ride it more!!! and defentily keep us posted if you find anything out on your 250
Originally Posted by bigred455
Not a CRF,but I have 450,RMZ a little over 120hrs,valves stayed exactly the same I check every 10hrs. My first check was at the 3hr mark and they have not budged. It is not unheard of to shim at the 15 hr mark,as long as you got them before they hit 0. You may not have to touch them for who know's how long,at the factory they could of been on the tight side leaving.Is this the first time checking? What were your readings?
Originally Posted by john3_16
That's impressive...what year ?
Originally Posted by Britt Boyette
I know they say to replace the valves when they go to Zero but, what do they normally run. I'm right at .006 on my 03 CRF 450R. Also, do the exhaust valves seem to wear quicker than the intakes or is it the other way around?
